Analysis of sulfuric Acid
Q. I want to do analysis of spent sulfuric acid, which is outcome of dyes industry. Strength of acid varies between 40-60% and impurities may be organic or inorganic. I am interested to know inorganic impurities. Major contributors may be sodium sulphate and sodium chloride.
Jayesh RupareliaEducation - Mumbai, Maharashtra, INDIA
A. Try heating 10 mL the spent sample in 150mL beaker [beakers on eBay or Amazon [affil links] with a matching watch glass on a hotplate until it reaches dense white fumes. Then, remove it from the hotplate, remove watch glass and allow it to cool down until there fumes are gone. Replace the watch glass and SLOWLY AND VERY CAREFULLY drip 30% hydrogen peroxide down the side of the beaker until the sample clears. Quantitatively transfer the mixture to a 1 liter volumetric flask and dilute to the mark with water. Analyze the sample for chloride using ion chromatography or titration with silver nitrate. It would be not be practical to determine sulphate in the sample. Sodium can be ran on the digest via AA or ICP.
Jarett BurgettAircraft - Wichita, Kansas, USA
Q. I want to do analysis of spent sulfuric acid, which is outcome of chemical industry. Strength of acid varies between 20-60% and impurities may be organic or inorganic. I am interested to know organic impurities.
K A ChaudharyEducation - Gandhidham, Gujarat, INDIA
December 7, 2012
? Dear Mr. Chaudhary,
Do you mind telling us what kind of organic impurities are you looking for? There are some methods for organic compounds, but every method has some chemical family it measures.
If you can specify, we may be able to help you. Best regards,
- Cañuelas, Buenos Aires, Argentina
December 11, 2012
Tip: Readers want to learn from Your Situation 🙂
(little can be learned from abstract questions, so many readers skip them)
Q. METHOD OF ORGANIC MATTER IN DEMINERALIZED WATER
K A CHAUDHARY [returning]- GANDHIDHAM, GUJARAT, INDIA
January 12, 2013
A. Hi cousin Chaudary. You cut & pasted your first question, and I don't know if this is an answer Daniel's request for clarification or if you just blew him off and are now asking another question. Such minimal effort on your own behalf -- an all-caps, punctuation-free, 7-word fragment -- while asking all the readers struggle to try to understand you, doesn't seem to justify a stranger putting in much effort for you :-)
Thanks for your understanding!
January 17, 2013
Thank you for your answer to my earlier query.
Q. My new question is regarding demineralised water plant. We want to analyse organic matter in outlet water sample from Activated Carbon Filter (ACF).
January 17, 2013
A. There's two things you could do with your DI water; send it out to a lab and have them run Total Organic Carbon (TOC) or get yourself a Chemical Oxygen Demand (COD) set up. The latter may not be sensitive enough. But, if it suits you, Hach Co. sells a good one.
Dave Wichern
February 14, 2013
April 4, 2013
Q. I want to know the standard method (conventional) of determination of NOx (NO + NO2) in low pressure BOILER Stack. We are using FURNACE OIL as a fuel having 3.0 % sulfur & 10 % Carbon Residue. K A CHAUDHARY [returning]Fertiliser - Gandhidham, Gujarat - India
Q. Please mention the flame temperature while the fuel is used as a furnace oil and combustion with air. K A Chaudhary [returning]- Gandhidham, Gujarat, India April 16, 2013
Q. WHAT WILL BE EFFECT IF CALCIUM CARBONATE IS INCREASED FROM 2.0% TO 5.0% IN POLY PROPYLENE BAGS. K A CHAUDHARY [returning]IFFCO - GANDHIDHAM, GUJARAT, INDIA July 15, 2014
Q. I WOULD LIKE TO KNOW THE EFFECT OF CALCIUM CARBONATE ON POLYPROPYLENE FABRIC AND ALSO SUGGEST THE RATIO OF CALCIUM CARBONATE & POLYPROPYLENE FABRIC WHICH GIVES HIGHER BREAKING STRENGTH. K A CHAUDHARY [returning]IFFCO - GANDHIDHAM, GUJARAT, INDIA July 17, 2014 |
Q. I want to do analysis of spent sulfuric acid, which is outcome of chemical industry. Strength of acid varies between 25-30% and impurities may be organic or inorganic. I am interested to know organic impurities. Can I analyse by COD method? It is possible or not?
HAWALDAR SALIMEDUCATION - MUMBAI, MAHARASHTRA, INDIA
March 26, 2020 -- apologies; slipped thru the cracks til July 3
A. Hello Hawaldar
The best way to analyze for organics is by TOC (total organic carbon analysis). The TOC-L series - catalytic combustion system along with a high salt kit.
To my knowledge the COD method is mainly used for determining organic matter in water using an oxidizer such as potassium dichromate. I have my doubts that you could get accurate readings in a 25% Sulfuric using the COD method, and the dangers of using a strong oxidizer for determination. Hope this helps.
- Winston Salem, North Carolina USA
July 4, 2020
