Stripping Copper from Brass: Tough but Practical Options
Summary for stripping copper from brass Discussion
Stripping copper plating from brass is difficult because the coating and substrate are both copper-rich, so a chemical stripper that removes one without affecting the other is hard to find. Mark Kruzel asked whether about 150 µin of copper could be removed from brass; later Norman Rose asked the same in the context of an old brass oil lamp. Goran Budija suggested electrolytic etching with acidified copper sulfate, using the plated object as the anode and copper as the cathode. For a more industrial rework problem, Frank Liou described a bronzing process on brass parts where traditional stripping protects the brass but leaves the acid-copper layer, causing dimensions to grow with each rework. Ted Mooney replied that this is the “holy grail” of stripping and doubted a suitable chemical solution exists, though electrolytic stripping might work on simple shapes. He advised improving process robustness to reduce rejects. A later note said MacDermid once offered a polysulfide strip that formed copper sulfide for removal without attacking brass.
Q. Is it possible to strip copper plating ~150µ” thick from a brass substrate?
I realize that brass (Cu,Zn,trace Pb) is a copper alloy. If it is possible, please provide a solution.
Thank You, M.K.
Mark Kruzel
electronics mfg – El Cajon, California, USA
Remove copper plate from brass lamp parts
Q. Can I chemically remove or reverse electroplate an old brass oil lamp that has a copper plating over the brass?
Norman E. Rose
Hobby – Bumpass, Virginia
A. You can use electrolytic etching process-acidified copper sulphate
on
Amazon [affil link] solution as electrolyte,object=anode;cathode=copper(it can be covered with cotton wool and wetted with electrolyte too),as current source you can use 4,5 V battery or hobby drill rectifier.Good luck and hope it helps!
– Cerovski vrh Croatia
Q. I and my colleague make the old-bronze-like treatment on brass parts;
This is the simple process: buffing & polishing, acid copper plating, black oxidation, brushing and powder coating.
And the part with defects would be stripped and reworked;
Here is the question:
the part has some precise dimensions; the traditional stripping is designed to protect brass substrate, and cannot strip the acid-copper-layer, so the dimensions are larger and larger in reworking.
Where to find the knowledge to solve this? Or a solution supplier? Thanks!
Frank Liou
– Guangzhou, Guangdong Province, China
A. Hi, Frank. I would hesitate to call your bronzing process “simple” if you can’t do it reliably and are still dealing with rejects and rework that keep making the items larger and larger; maybe it’s more difficult than you realize yet :-)
You seek the holy grail of stripping when you seek a process that “knows” what part of the object you want removed and don’t want removed when they are made of very similar materials. I doubt that you will find a suitable chemical solution, although electrolytic stripping might possibly work if the shape of the parts is simple and favorable.
Personally, I think you should concentrate your efforts on making your simple process more robust and reliable so you have very few if any parts to rework. Best of luck.
March 1, 2012
March 4, 2012
Q. Ted, thanks for your replying.
Just like you said, it’s not simple, I’m not very good at expressing my thought in English, -_*!
Having the question for 2 reasons:
1. the old-bronze-like order is few and the part is not simple at all;
2. I’ve seen a process to strip copper from brass in another workshop!
It’s totally different from the traditional stripping.
The process is electrolyzing; at first the part is reacting in the tank, and the surface is turned to white slowly, just like some deposition layer. When the part is totally white, then washing the part with acid solution, the part turned to brass-like yellow.
I’ve been told the process is secret; the only thing I know is the technique is from Taiwan; I don’t know how it works.
The brass substrate and the acid-copper layer must be different in some aspect.
I hope somebody can teach me this, or do some business with me.
Anyway, I will put my focus on improving yield rate — do my best to make less reworking. Thank you.
Frank Liou
– Guangzhou, Guangdong Provice, China
A. Hi Frank. Your English is very good, and I can’t speak a single word of Chinese … so thank you for your effort.
I am not familiar with that stripping approach, but it is very interesting. Thanks for telling us about it. It is possible that some other reader will recognize it. It may be a licensable proprietary product rather than a secret held by one person, or it may even be generic knowledge that I am simply ignorant of. Good luck.
March 5, 2012
March 9, 2012
A. Following on from the comment re forming a coating and cleaning that off, MacDermid used to offer a concentrated poly sulfide based strip that formed a copper sulfide coating which you then cleaned off mechanically, or chemically in cyanide, and then re-immersed until all copper removed. The polysulfide did not attack the brass. Slow, messy but effective.
Geoffrey Whitelaw
Geoffrey Whitelaw
– Port Melbourne, Australia
Q. Can you give me the name of the process to strip copper from brass that Macdermid supplies?
Kivanc Ekinciler
Defence Industry – Ankara, Turkey
January 17, 2013
