Copperware -- too much vinegar
Q. I have some very expensive copperware that had darkened from oxidation after some use on the stove.
I tried using a salt and vinegar
⇦in bulk on
Amazon [affil links] mixture to restore the items, but ended up leaving it on too long.
The oxidation was mostly removed, but the result is terrible:
instead of the original mirror-like copper surface, I've got spots that are sort of milky (the cloth I used to wipe the vinegar off with turned greenish).
Is it possible to fix this?
student - Vancouver, Canada
A. I'll bet a proper polish like Brasso ⇦ this on eBay or Amazon [affil links] will bring the shine back pretty quickly . If not, you'll ned to buff it back to brightness.
