Brass fireplace doors are discoloring
I have a gas fireplace with brass doors. The brass doors discolor terribly.
Does this mean I need a clear coat?
What should I use?
I'd appreciate any help.
Thanks. Peggy
Peggy Shaffer
- Tullahoma, Tennessee
Hi, Peggy. Bright brass is always lacquered or clear coated. It turns brownish if it isn't. Some people prefer the brown look, but if you want it shiny you must lacquer or clear coat it. Brass lacquer is designed for use on brass and is easily removable so you can re-do it or change your mind. Lacquer is flammable, so don't do it near an operating fireplace, and let it dry.
You can buy single rattle cans of brass lacquer this on eBay or Amazon [affil links] , but if your needs are special or for larger volumes, please contact G.J. Nikolas [a finishing.com supporting advertiser].
