Treatment for 2B finish to a uniform appearance
I have designed and built a framework structure using 7 ga 304 S.S. The outside surfaces have been polished to a #7 mirror finish, the inside surfaces have a 2B finish, I am looking for a method or material that will create a uniform appearance to the 2B finish without sanding, buffing, or disassembly of the framework. Any advice will be greatly appreciated.
Bob Szabomachinery manufacturer - Holland , Michigan
Hi, Bo. You have ruled out mechanical treatments, so you are apparently looking for a chemical that will create a uniform finish on the stainless steel, starting from a non-uniform finish.
I am not sure that success is possible, but I would start with an alkaline detergent solution or
pumice
⇦ this on
Amazon [affil links] and a scrub brush
⇦ this on
Amazon [affil links] to remove any oils, dirt, and finger prints, then try a citric acid passivating solution, available from Stellar Solutions [a finishing.com supporting advertiser].
September 23, 2009
