Electroless nickel plating is not adhering to CuW
I am responsible for a project of surface finishing on 20Cu80W or
10Cu90W substrate. The finish is 2 µm Au / 2 µm El Ni / CuW. I use Pd as catalyst for El Ni. Ni layer peel off during thermal testing (room temp. to 400 C).
Would you have suggestion to improve the adhesion?
optoelectronic mfgr - Hong Kong,
Hi, Benny. Getting adhesion on tungsten is very difficult because it is a refractory metal, but strong acids, followed by nickel strike, followed by diffusion often work; the ASM Metals Handbook, Vol. 5 has a great chapter on the subject. Good luck.
September 23, 2009
