  Thread 241/97
Repairing a hole in kitchen sink
Is there any way to repair a small hole in a stainless steel kitchen sink? e.g., patch, putty, etc
John Smith
student - Melbourne, Victoria, Australia
publicly reply to John Smith
Now that depends on a great deal of criteria that you did not mention. Obviously, you could put a rubber stopper in it. You could also use one of the floppy rubber sink drain stoppers. All of this is pretty ugly. If you had access to the right toys, you could weld a patch into or onto the hole. Again ugly or expensive. Buying a new sink is the cheapest way out for most criteria.
publicly reply to James Watts
Epoxies like JB Weld this on eBay or Amazon [affil links] may surprise you with their durability if looks are not paramount. My outdoor shower has a cast bronze mixing valve that split open from freezing damage; I can't find a replacement and reworking to accommodate a different one is going to be a major plumbing project. JB Weld this on eBay or Amazon [affil links] is holding up fine so far after 3+ years :-)
publicly reply to Ted Mooney
