Fabricating anodes for hard chrome plating
"Hard Chromium plating"
by Robert K. Guffie
Hard Chromium plating by Robert K. Guffie
(rarely)
(rarely)
Q. I have a bowl mold that is 6 cm deep and it has a groove in its bottom part. What is the best way to make sure hard chrome will be plated in the groove? I am having a hard time to hard chrome the grooved part.
Mike Josh
- Amman, Jordan
November 8, 2021
Ed. note: While you await responses you might send a photo of that mold to mooney@finishing.com for posting here. A picture is worth a thousand words :-)
Q. Hello , I would like to know if it is general knowledge to use steel as a conforming anode for hard chrome plating, and if so, is there a copyright on the process of using such a method.
Charlie Vega
- Melbourne, Victoria, Australia
A. It is general knowledge NOT to use steel as anode for chrome plating. It dissolves and contaminates the solution, also gives other problems. Better use lead and if not possible use Stainless Steel.
Guillermo Marrufo
Monterrey, NL, Mexico
"Chrome Plating Simplified"
by Clarence H. Peger
(You're unlikely to find this for sale ... but copies are in select libraries)
chrome_peger
from AbeBooks
* rarely available *
A. I think that it is general knowledge enough to not be patentable. Then, it is not practical as it puts iron ions into the chromic solution which causes problems. I have used steel wire for a very precision anode for spaces where lead that thin was absolutely too flimsy. Tiny amounts of steel anodes can be used if you are using a porous pot or similar technology to remove the contaminants formed. Cast lead mats like those Clarence Peger proposed in his book are very easy and very practical after you get the construction knack down.
