CORROSION-RESISTANT BLACKENING PROCESS?
WE WANT TO BLACKEN CAST IRON AND MILD AND SPRING STEEL PARTS. WE CURRENTLY USE SODIUM NITRATE TO COLOUR THE MATERIAL BUT ACHIEVE A BLUE FINISH.
WE ARE LOOKING FOR BLACKISH FINISH ALSO THE SAME SHOULD BE CORROSION RESISTANT AS IT WILL BE WORKING IN MACHINERIES.PLEASE HELP US TO ACHIEVE BLACK FINISH.
-MANUFACTURING SMALL MACHINERY PARTS. - KOLKATA, WEST BENGAL, INDIA
You should try cathodic electro deposited coating. It will give you 20 microns of dry film thickness which can sustain 1000 hours of salt spray test (astmb633.htmlb117.html" -->. It will give a semi glossy black surface.
For sample coating on your components, you can contact us. Hope this helps.
Mohali, Punjab, India
A PRE TREATMENT PROCESS SHOULD BE TAKEN CARE OF FOR CAST IRON COMPONENTS. A DESCALING BATH CONSISTING OF 200 GMS \ LTS OF caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] AND 20 GMS \ LTS OF POTASSIUM PERMANAGNATE SHOULD BE USED TO DESCALE THE CAST IRON AT 70 -80 °C.AFTER THIS THROUGH RINSING AND HCl ACID PICKLING WITH INHIBITOR AT 1% ON ACID VOLUME SOAKING FOR A MINIMUM PERIOD OF 30 MTS IMPROVES THE SURFACE. NOW KEEP 1% CAUSTIC SODA SOLUTION AT BOILING TEMP. 70 °C AND THEN GO TO THE BLACKENING BATH WHICH CONTAINS CAUSTIC SODA 650 GMS \ LITRE , SODIUM NITRITE , 200 GMS \ LTS SODIUM NITRATE 150 GSM \ LTS AND SODIUM CYANIDE 1 GMS \ LTS. THE TEMPERATURE SHOULD BE 135 - 145 °C WITH EFFERVESCES BUBBLING OUT IS THE RIGHT TIME TO INTRODUCE THE COMPONENT FOR BLACKING AFTER 1% CAUSTIC HOT DIP. DON'T WIPE OFF OR RINSE AFTER BLACKING ( OXIDISING ) . FINALLY APPLY DIESEL 25% + CUTTING OIL 75% DIPPING SHALL IMPROVE THE SURFACE TO GIVE A SMOOTH AND BEST FINISHING. THERE IS NO NECESSITY FOR THIS OILING BATH HEATING.
C PRAKASHAMchemical company - KOLKATTA, CHENNAI, INDIA
