Removing a clear coat finish from a bronze statue
I would like to remove a clear coat finish from the face of a bronze Buddha statue located in a New Jersey Buddhist temple, so that the face can be painted. I am not certain if the protector is oil or acrylic based. My concern is not to damage the bronze finish with the incorrect chemical remover.
David Newmanarchitect - Lawrenceville, New Jersey
Hi, David. Although you should obviously test in a non-conspicuous place, because things sometimes aren't what you expect, most organic paint removers should not have much effect on bronze. I would start with acetone, since this is commonly used as a lacquer thinner ⇦ this on eBay or Amazon [affil links] Warning! highly flammable! and may work fine. Although it is highly flammable, common nail polish remover is acetone plus water, so it's not exotic toxic chemistry. If that doesn't do it, a methylene chloride based "Aircraft Stripper" should -- but this is a really toxic brew that can only be used with great ventilation and good personnel protective gear including goggles ⇦ this on eBay or Amazon [affil links] and rubber gloves ⇦ this on eBay or Amazon [affil links] .
