Removal of copper contamination from MSA based tin-lead plating solution
Is there a way or method to remove or reduce copper ions in SnPb or pure Sn plating baths (MSA based)? Except plating it out at high current density?
Gilman Jimenez
semiconductors - Calamba, Laguna, Philippines
Kumusta na kayoo, Forget it Paray, dump the bath and start over before the solder starts voiding during solderability test after steam age. With SnPb MSA baths its good to use two baths, one for striking and one for plating since the strike will get loaded up with Cu if you are not Ni plating prior. Then just routinely dump the cheap strike.
Dave Kinghorn
Dave Kinghorn
Chemical Engineer
SUNNYvale, California
