Electroless nickel (EN) suffers non-conductivity
We had some aluminum shelves electroless nickel plated. They came back with a yellow hue and were non-conductive. Any ideas?
Truman G. Glasscock
- Huntsville, Alabama
Does your electroless nickel plater also do anodizing?
Todd Osmolski
- Charlotte, North Carolina, USA
Second of two simultaneous responses -- 2003
Probably, an adhesion bake at an excessively high temperature oxidized the surface. Adhesion bake on aluminum should be at 375 F for non-heat-treatable alloys, or 250 F for heat-treatable alloys (MIL-C-26074 [⇦ this spec on DLA]E, Classes 3 & 4, respectively). A straw colored tarnish suggests a hardening bake > 600 F, as performed on steel (Class 2).
Ken Vlach [deceased]
- Goleta, California
The symptoms you describe indicate that the aluminum was not electroless nickel plated but rather it s anodized and dyed gold. Come back with more information. Electroless Nickel freshly plated, especially only after a few days WILL conduct. Anodizing is insulating.
robert probert
probertbanner
