High temp powder coating pretreatment
have experienced problems with complete delamination of powder coating on cold rolled steel after heating to 650 F.
Pretreatment used is 7 stage iron phosphate. Is anyone aware of a better pretreatment for powder coating cold rolled that can withstand elevated temperatures.
Patrick Patton
Dear Patrick, I believe I have a solution to your paint delamination problem. What is happening is the phosphate under the paint is breaking down. You will have to go to a non phosphate treatment. Chemetall Oakite has 2 products that have worked in this type of application. They are UltraSeal and ChemSeal 3620 C. Regards,
Danny Murchison
- Memphis, Tennessee
For applications at 650f powder coating may not be the best choice no matter the pretreatment. You may want to consider a ceramic coating.
Robert Hewitt
- Columbus, Ohio
