Thread 24/26
Hardwearing coating of Aluminium
At the Philips Centre fo Manufacturing Technology Centre I work in a group specialised in tribological issues. Most of my time I am concerned with air bearings.
Because of reduction of weight a lot of my customers want to use Aluminium. To protect the aluminium surfaces we usely apply a hard anodisation process. My question is: Are there any other processes/coatings that give me a hard hardwearing surface.
The most critical condition for the coating process is that the dimensions of the parts have to be toleranced within a few micron. The second condition is that sharp edges have to remain sharp.
If anyone has a suggestion do not hesitate to reply.
Justus PostPhilips Centre for Manufacturing Technology - Netherlands
publicly reply to Justus Post
Chrome plating is one option, but it very probably would require post plate machining to maintain the dimentions.
Electroless nickel is a more viable option. Consider a low P one for no bake or low temp bake after plate. It will require a good shop, since it will probably be a one try per part operation and amount of deposit very tightly controlled.
Hard coat is probably your best option. Metalast impregnates with silver. It might enhance your hardcoat.
James Watts- Navarre, Florida
publicly reply to James Watts
Then there is the CVD diamond-like-carbon (DLC) which is typically under a micron thick. It is suitable for low load applications on aluminum per our experience.
Mandar Sunthankar- Fort Collins, Colorado
publicly reply to Mandar Sunthankar
