Coating/painting corroded conduit in underground spaces
I'm putting together a contract to clean up the corrosion and calcium deposits that have built up on exposed grs conduits and metal sprinkler piping that is located in some underground spaces.
The corrosion and calcium deposits are a result of water leaking and running down the walls and over the exposed conduits, etc. Often the corrosion occurs where the conduit stubs out of the concrete wall/floor.
CLR
clr
Primer for Galvanized Metal
primer_for_galv
I'm wondering what kind of products would be easy to apply, adhere to both grs conduits, metal piping and concrete - and can provide protection from future corrosion.
Thanks, Mike
Mike C [last name deleted for privacy by Editor]
engineering - Seattle, Washington, USA
Hi. Calcium deposits can be removed with products made for the purpose like Lime-Away or CLRthis on eBay or Amazon [affil links] . I don't think that these mild acids would harm concrete or galvanized conduit and piping if used very judiciously. Diluted vinegar in bulk on eBay or Amazon [affil links] might work but is a bit aggressive.
If you wish to paint the galvanized runs, you will need to use a primer for the purpose.
because other paints will not stick to galvanized surfaces. Such primers ought to work on any bare steel as well. Top coat, but don't use alkyds as they saponify with galvanizing.
October 16, 2008
