Rapid prototyping ABS plastic
During the rapid prototyping process we use ABS(acrylnitrile butadene styrene ) plastic. After the production has finished we start finishing it.
However the final product does not satisfy us because of the lacks in the finishing part. Could you please give advise to us?
With my best regards,
Ozlem Gur
rapid prototyping - Istanbul, Turkey, Turkey
Quantity, size and shape has a lot to do with what method to use for surface finishing. For reasonably large quantities, mass finishing systems is the way to go. Depending on the present surface finish you may need more than a one step process; however, the final step will be a treated (polishing blend) of dry organic media.
tony kenton
AF Kenton
