Plating aluminum without zincating
Q. I need to electroless nickel plate aluminum parts for a space instrument. Zinc is not allowed. When using zincate to prepare the aluminum for the electroless nickel, is there zinc remaining on the part or is all of the zinc removed in the electroless nickel bath.
William Perry
Research and Development - San Antonio, Texas
"The Surface
Treatment &
Finishing of
Aluminium and
Its Alloys"
by Wernick, Pinner
& Sheasby
pinner
(note: this book is two volumes)
AbeBooks
A. Good luck! Most of the zinc stays there, and it is difficult to electroplate aluminum without zincating. The only alternative I've heard of is to electroplate onto a phosphoric acid anodized aluminum surface, but I don't personally know anyone who has done it.
A. Teflon can be applied with a dip process or can be sprayed, after the last rinse but before sealing.
drew nosti
Drew Nosti, CEF
Anodize USA
Ladson, South Carolina
anodizeusa1
Update! Although I'm not familiar with the process myself, Raafat Albendary reports a method to electroplate onto aluminum without involving zinc in thread 173/11.
January 30, 2025
