Vacuum compatible/nonmagnetic/non electrically conductive materials
I am looking for some vacuum compatible materials that will be subjected to the following conditions
1) T=170 F
2) P=10^-6 Torr
3) 2 Tesla magnetic field
4) materials must be low outgassing
I started with aluminum since it is vacuum compatible and nonmagnetic. However, the magnetic field will cause inductance in the electrically conductive aluminum which will interfere with the 2 Tesla field. Then I thought of anodizing the aluminum to make it nonconductive. However, the anodizing will cause high outgassing in the chamber. I believe nylon will become too brittle at this temperature. I am hoping for some suggestions.
Frank Arnolds
- Culver City, California
How about Teflon. UHMW polyethylene plastic might work, but will soften at that temp.
A very thin layer of highly resistive material such as SST or chrome and/or just an epoxy spray coat might work. Epoxy could also seal the anodized layer.
Mandar Sunthankar
- Fort Collins, Colorado
CPVC, chlorinated PVC (rated to 208 deg F) should perform well in this application and is far more cost effective than Teflon.
Jeremy Gray
- Melbourne, Australia
Ultem 2200, a glass filled polyetherimide (rated to 400 degrees F) should work. The costs will be a bit hi.
Eddie De Anda
- San Diego, California
