Copper electroplating on copper
Hi,
I am trying to electroplate Copper onto a copper coated substrate to get a thick layer of Copper on my substrate. After I plate Copper, the moment I take out the sample from the electrolytic solution, the plated Copper along with already present Copper on the substrate peels off. I am not sure of this situation. Could you please suggest me the reason.
Sud
- Raleigh, North Carolina
Your question is broad. We need to know what solution you are using for copper plating, what the substrate is, how that first layer which is pulling off got on the substrate in the first place, etc. But it is reasonably clear that the initial copper layer is defective.
Hi, Sud!
Mr. Ted is right. It would really help if you describe to us your plating setup and the material you want plated. But for starter, and if you can, you may rub (with emery paper) off a small amount from the original plated copper to expose a new copper layer. Then try to plate again.
H. Dacillo
- Manila, Philippines
