Chlorine bath of G60 coated parts
Q. We manufacture structural parts with a G60 galvanize finish. Recently, a customer used a chlorine solution to spray mildew from the walls of their unfinished house.
Can anyone tell me the long-term effects of a chlorine bath on a G60 coating?
This is in Florida, so humidity will be high, throughout the life of the product, even though exposure to chlorine was a single bath.
Thank you, bob lutz tampa
Robert W. Lutz
- Florida, USA
A. One nice thing about a public forum is if my guess is poorly founded someone will usually correct me. I doubt that the chloride ion itself is a problem, if the solution was rinsed, because galvanized finishes are widely used for saltwater exposure (anchors, boat trailers, etc.). However, to keep the chlorine in solution, bleaches have a fairly high caustic content--and zinc dissolves in alkali as well as in acid.
I think if the homeowners diluted the bleach substantially, which I would expect based on the economics of spraying a house, and then rinsed it, than it would have no impact. But if they sprayed full-strength bleach (which is quite difficult to rinse) there might be a problem.
