Re-coat brass
I know that if brass gets a tarnished color I can strip the varnish with acetone ⇦ this on eBay or Amazon [affil links] Warning! highly Flammable! or nailpolish remover and then polish. Can you tell me what to use to recoat the finish in order to prevent tarnish? Thank you.
Dorothy Carrick- Columbus , Ohio, USA
Hi Dorothy. Brass Lacquer is best, although other clear coat products may be okay. Good luck.
March 16, 2013
