How to achieve 2000 hours corrosion resistance in painting system
1.Suggest a Painting process to achieve 2000 hours of Neutral salt spray for a fabricated chassis with multiple weld joints (MIG weld) 2.Suggest a paint for the above requirement as to achieve 1000 hours Ultra violet (UV) resistance
RAGOTHUMAN PADMANABHAN
- HOSUR, TAMILNADU, INDIA
Hi, Ragothuman. What pretreatment and painting processes are your currently using? What salt spray hours and UV resistance are you presently getting? It may give us a clue to the weakest link; for example, does your system lack an e-coating step or zinc phosphatizing? Those are probably your starting point. Good luck.
Dear Ted Mooney, P.E.,
Good Question ......... !
Atul Bhide
Atul Bhide
jobshop / applicator - Mumbai, India
