Rust Preventative for Iron Castings
Q. My company machines Cast Iron EGR Valve Housings for a large Tier II Automotive supplier. We currently have the part Phosphated & Oiled but our Customer is not satisfied with it's RP life. Does anyone have suggestions of other options for rust prevention of cast iron parts ?
Robert Snider
- Leslie, Michigan, U.S.A.
A. We manufacture an environmentally safe product called Picklex® [affil links]®, which can provide a very long term rust protection (applied at room temperature) if stored indoors (more than a year or two). If the part is pickled in Picklex® at around 145 °F, it passes 20 hours of salt spray test (astmb633.htmlb117.html" -->) without any top coat, which will provide a long term protection. With applying hot oil over the Picklex® coating (after heat drying), it passes 72 hours of salt spray test.
Ranjit Sen
- Huntsville, Alabama
Do spray on rust preventatives work?
Q. I am looking for a simple method of preventing rust formation on stripped metal parts (steel and iron) after bead blasting or other chemical/mechanical rust removal. Online stores market spray bottle products (e.g., Picklex® [affil links]) which they claim will prevent rust from forming on stripped parts. Do they work?
John Wogec
car restoration - Roseville, California
February 11, 2015
A. Hi John. You should apply a rust preventative after blasting or chemical stripping to prevent flash rusting; if immersion treatments aren't practical for you, yes, the spray-on products work. But, like everything else in this world, rust preventatives have limitations. They are generally intended for short term storage until you get to the next step such as painting, plating, or powder coating. They are not intended for exterior exposure. Good luck.
February 2015
