Resin Recovery process
As newly we bought bombing process at our plant after total gold loose 2 kg we started to recover but unfortunately I don't know how to recover at the best way with less cost. Please if any body know about send to my E-mail. with best regards.
tauffiklazurde - second industrial city, riyadh, saudi arabia
If you are trying to recover the gold from your bombing solution (Alkaline Cyanide & Hydrogen Peroxide). There are a number of electrolytic gold recovery units available. The resins are normally used after the electrolytic stripping to remove the last traces of gold. If your problem was due to incomplete stripping of your resin you may want to check with your resin supplier for proper methods. If you are burning your resin and trying to digest the carbon residue in aqua regia, it may take a number of digestion cycles to extract all the gold. I was in your factory about 8 years ago and at that time you were electro-stripping the pieces, the bombing process seems to be a step backwards.
Jim Sivertsen- Alden, N.Y., U.S.A.
