Titration process for ABF
At present we are using Ammonium bifluoride with water for matte finish now we want analyse the chemical means titration of solution and finding out the percentage of Ammonium Bifluoride can any one help me and give titration process for this.
Thanks in advance.
Ashapura Chemicals - Ahmedabad, Gujarat, India
Take a look at letter 22907 and then do a search of all the letters using the search engine. You will find several letters. Now, no one can help you until you tell us the rest of the story. What are you etching? Do you intend to analyze before use, or after use. Before is dirt simple and after use requires a lot more attention to detail. Is there any other acid in this mixture.
James Watts- Navarre, Florida
Thanks Mr James please note that we use this solution means water with 100 Gms per litr of ABF for matte finish on aluminum we want titrate the solution before & after use. Please can you help in this ?
SatishAshapura Chemicals - Ahmedabad, Gujarat, India
