Sound technical content, curated with aloha by
Pine Beach, NJ
for Metal Finishing since 1989
Bead wire Plating and effect of composition
Dear Sir, Please through some light on following Points:
Point No. 1: What is the role of Tin in Bead wire Bronze plating system? Generally For getting better adhesion with rubber, Industry trend is to keep Tin content in Bronze composition is maximum 3 %. I would like to know what is the effect if we increase the Tin content from 3 % or we reduce it below 1 %.
Point No.2: Which type of Bead wire will provide good adhesion and also cost effective, if we have to choose from Brass coated and Bronze coated bead wire and why? With Best Regards, Sushil Mandot Scientist-C
- Kankroli, Rajasthan, India
Dear Sir,
The Stannous Sulphate is added to work as a binder. Increasing above 2% will reduce the malleability of the coating.
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
