-----Removal of heat treat scale from martensitic tube
My company is currently looking for a solution to a very unique scaling problem. We wish to remove the scale imposed on both the inside and outside of a martensitic steel tube of non-constant cross-section by a high heat and water quench process. Is there a particular process that readily lends itself to this application?
Russel Kozak- Northville, Michigan
There is a possibility that you could run them thru a vacuum furnace or a furnace with a reducing atmosphere, but I kind of doubt if you can go to a high enough temp. It is worth looking into. There are acid pickles that may reduce some of it. There is a 3 and a 4 step chemical process for it (McGean-Rohco is the one that I used), but it is less than optimum if the part is really blue or a dep black.
James Watts- Navarre, Florida
Conventional pickling with either sulfuric acid or hydrochloric acid will remove heat-treat scale. Less aggressive acids like citric, oxalic, phosphoric, etc. will not completely remove anything more than mill scale.
Toby Padfield- Michigan
Best to avoid scale formation. A. O. Smith has a water-based coating Ceram-Guard 96 which protects metals from oxidizing to 2300 F and then spalls upon quenching. Let us know any results (I only know about from an ad).
Ken Vlach [deceased]- Goleta, California
