How do I color muriatic acid without high expense?
I have been making imitation rocks and am interested in coloring the concrete with muriatic acid ⇦ this on eBay or Amazon [affil links] . I know some simple household items that can be used to color tans, gray, and green however, I am interested in information on what might be used to color the acid a dark brown without paying the high cost of colored muriatic acid. Your help is much appreciated.
Paul E. Frye- Summerdale, Alabama
Paul, muriatic acid does not contain a dye. The product you are talking about may contain muriatic acid, however. Pressure wash it, let it dry and apply a polyurethane paint that is made for concrete if you do not like the specialty product. For home brew's, it is trial and error with a small probability of a beautiful end product.
James Watts- Navarre, Florida
Dear Paul :
I suggest you use ferric chloride ⇦ this on eBay or Amazon [affil links] instead of coloring HYDROCHLORIC acid. It will give you the desired yellow to brown depending on the concentration.
Hamed M. Marie- Cairo, Egypt
