Enamel Coating
I am very unfamiliar with the porcelain enamel coating process, and I was curious of the steps I needed to take to get steel grill grates porcelain coated.
Matt Yarder
- Toledo, Ohio
This is a high temp fired coating. Absolutely not a home project. If you want basic process, use the encyclopedia or put "porcelain coating" in your search engine. Leave the " " out and you will get a few hundred thousand hits.
