Surface Tension
I want to know the easiest laboratory method for calculating the surface tension of the liquid. This liquid contains dissolved PAHs and organic contaminants.
ISLEYEN- DENVER, CO, USA
Try a surface tension torsion balance. It is quick and relatively easy to get consistent results
