Stripping of Cu/Sn alloy
I want to know how to strip a Copper/Tin alloy deposit. The deposit composition of Cu/Tin is 65/35. Thanks for your kindly help.
David Koo
- China
Any question relating to stripping must include both the coating AND the base metal- otherwise the question is meaningless.
Geoffrey Whitelaw
Geoffrey Whitelaw
- Port Melbourne, Australia
Thanks Geoff. The substrate is brass or zinc-die casting. And, the plating layer is copper and then Cu/Sn. Thanks for your help.
David Koo
- China
