Heating up EN Baths
adv.    industrial heating systems
We are an Electroplating Job Shop and have been experimenting with different ways of heating up Electroless Nickel Plating baths. Glass heaters are not an option ; I am looking for coil material that can be used with a hot water boiler or any other ideas that have worked for you. Thanks in advance.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
The conventional coil material is teflon. If you are using a stainless steel tank with an anodic protection system to prevent spontaneous plate-out, I can't see offhand why stainless steel heating coils could not be used if protected against plate-out (but I have no actual experience in that).
I have not used one, but several companies sell a small external heater that uses extremely turbulent flow to retard the plate out that you would normally get from using steam heat temperatures. I was impressed by the claims and from a person that had one. Hot water is too slow. You will have bath degradation. The optimum way to operate EN is to have it get to temp rapidly and then get product in it immediately with no down times for lunch. Adding your make up water after heat termination at the end of the day allows the temp to get out of the autocatalytic zone faster. Cooling water thru your steam heater really helps also.
For coils, I personally prefer titanium for greater corrosion resistance and they cost just a little more than SS, but you may want to consider the design and construction of a double wall SS tank which would be heated with boiling water between the walls. This would provide for a more uniform heating and larger area thus avoiding localized hot spots.
Guillermo Marrufo
Monterrey, NL, Mexico
