Stripping rubber liner out of gas tank
I AM LOOKING FOR AN ACID THAT EATS RUBBER BUT NOT METAL. I AM CLEANING THE INSIDE OF A FUEL TANK THAT IS LINED WITH RUBBER. I DON'T WANT THE RUBBER AND I DO NOT WANT TO DAMAGE THE FUEL TANK. CAN YOU HELP ME WITH THIS?
GIL WISEMAN
- WESTMINSTER, COLORADO, USA
I am in the same predicament. I have to remove old gas tank line that applied incorrectly and peeling off because it has been sitting w/o fuel in the tank. Neither concrete cleaner, or acetone works. Did you find something that worked? Please let me know.
Tony Adkins
- Madison, Wisconsin
Use acetone this on eBay or Amazon [affil links] Warning! highly Flammable! . I just used it work great use at FULL strength for best results.
Bike Guy
- Canada
