HOW TO TURN BRASS BLACK?
Q. Is there a way of turning brass black without painting it. I was told there was a product that can do this. Any help would be appreciated.
22792
GRAHAM LEGGETT
- SUNDERLAND, TYNE AND WEAR, ENGLAND
A. First moisten the surface with strong vinegar in bulk on eBay or Amazon [affil links] and then suspend the part in ammonia this on eBay or Amazon [affil links] vapor (inside a lidded bucket with an inch or half an inch of ammonia will work) Repeat every five or ten minutes until the desired patina is at hand.
Lee Cordochorea
- Portland, Oregon
Brass Black Metal Finish on
birchwood_brass
A. Van Dyke's Restorers has a product called "Brass Black" that does the trick.
Suzette Pondillo
- Horseheads, New York
A. Make a solution of sodium polysulfide by dissolving flowers of sulfur this on eBay or Amazon [affil links] in a solution of sodium sulfide. Either paint the solution onto the part, or better still, soak the part in the solution. It will form an adherent layer of copper sulfide, which is black. The solution really stinks and gets into your clothes, so you will be all alone if you go the pub!
A. Graham,
I assume you want to make the receiver of this rifle black. You might want to check on this. Some rifles were made with brass receivers and were never colored. If you do decide to color the brass make sure it is a product that will hold up to the use the rifle will get. Some newer guns with alloy receivers are painted with epoxy type paints that hold up almost as good as the bluing on the barrels and look almost the same.
Good luck,
Ed Kay
- St. Louis, Missouri
