Electroplate lead
I make stained glass suncatchers. I would like for the finish on the lead to be bright silvery or chrome. Is there a way for me to electroplate the pieces myself?
Marie Ryan- Baton Rouge, Louisiana, USA
No plating is very expensive to set up and expensive to maintain. Find a plating shop that has done this work. One of the largest problems is cracking the glass by thermal shock; out of a hot soak clean and into a cold water rinse.
Jon Quirt- Minneapolis, Minnesota
