GEL FOR ACIDS
FOR CLEAN THE WELDINGS SIDES IN STAINLESS STEEL PARTS, IS NORMAL TO USE A ACID MIX HF + NO3H, BUT IS DANGEROUS. I READ THAT IS possible TO USE IN GEL FORM. CAN YOU HELP MI FOR TO FIND ANY PRODUCT FOR "GELIFICAR " THE MIXTURE OF THIS ACIDS?
REGARDS,
BRUN ANTONIO
- CASTELLDEFELS, BARCELONA, SPAIN
For cleaning the weld areas of stainless steel parts, it is normal to use an acid mix of HF + HNO3, but it is dangerous. I read that is possible to use this in gel form. Can you help me find any product for "gelifying " the mixture of these acids?
Kadir Levent
- Istanbul, Turkey
