Sulfamic acid reactions
Hello
I am a university student that I have a research about sulfamic acid reactions. I want to know the result of the reaction of sulfamic acid with :HNO2, NO2- & NaNO3 and whether special conditions are necessary (heat or catalyzer ...) for them or no? I hope you help me.
sulfamic acid + HNO2 ----?----> ?
sulfamic acid + NO2- ----?----> ?
sulfamic acid + NaNO3 ----?----> ?
- Mashad, Khorasan, Iran
NH2HSO3 + HNO2 -> N2 + H2SO4 + H20
same as above - intermediate HNO2
sulfamic acid + NaNO3 ----?----> nothing will happen, cause NO3 can't be reduced
Heinz Meurer
environmental controls - Oberahr, Germany
Ed. note: Thanks for helping Zohre out, Heinz, although my own sense was that he wasn't so much doing research as just submitting his homework assignment so he wouldn't have to do it himself :-) -- Ted
When we strip our electroless nickel tank we have used a 3% nitric acid strip and it is suggested to do a final rinse with sulfamic acid
https://www.pfonline.com/articles/109802.html
"To prevent the effects of nitric acid contamination, it is good practice to use a final rinse of sulfamic acid in the EN tank prior to making up a new solution."
How much sulfamic acid do we need to add to the final rinse?
Plating - Colorado Springs, Colorado, USA
Ed. note: I suspect that it's not critical at all, and the author is simply suggesting that some sulphamic acid would be better than straight water; but the more you add, the more you have to dispose of. You should be able to reach the author, Brad Durkin, at Macdermid.
