Effects of repeated burning off of powder coating to the galvanized steel sheet metal
We produce sheet metal components from galvanized steel sheet metal, which we then send out for powder coating. We are currently having repeated problems with our powder coat supplier. They have had to repeatedly powder coat, burn off powder coat, re-apply powder coat, burn off powder coat in an effort to achieve the quality finish we expect. My question is, what are the effects of the repeated burning off process to the galvanized steel? Does the repeated burning process continually diminish the zinc coating on the steel?
Christine Levengood- York, Pennsylvania, USA
Redish brown patina for iron:
iron chloride..........
15gm water or pure alcohol.
.1 lit Solution must be brushed on grease and oxide free object(very thin).
Every layer must be well dried. Can be lacquered or waxed.
- Zagreb,Croatia
