  Thread 221/97
SURFACE FINISH OF ALUMINUM ALLOY PISTON
WE MANUFACTURE ALUMINUM ALLOY PISTONS(12 TO 18% SILICON). AFTER HEAT TREATMENT THE CASTED SURFACE FINISH BECOMES DULL AND TENDS REFLECT DIE MARKS. WE REQUIRE SURFACE TREATMENT WHICH CAN GIVE AN EFFECT BETWEEN SHOT AND SAND BLASTING.
SANJAY GARG
- AGRA, U.P., India
publicly reply to SANJAY GARG
Could use some more information like are you looking to achieve a specific RMS or just remove the discoloration? Also, volume information would be helpfully in determining the most cost effective method and/or can you afford new processing equipment.
tony kenton
AF Kenton
publicly reply to AF Kenton
