Base metal choice
I need to fabricate some parts that eventually will be chrome plated and wonder what base metal would be the best choice. I will have to fasten pieces together before plating and would prefer to silver solder or braze them. Would the use of brass or copper be a good choice and offer any advantages?
Thanks for the help.
Stephen Mrachek
- Winona, Minnesota, USA
Brazing should be okay even if the parts are steel. Brass or copper would be fine as an alternative to steel also.
