Brass electroplating
I have a problem with BRASS ELECTROPLATING. The problem is the appearance of faint yellow and some times the coating is not shiny. Kindly give your opinion.
- Abha, Aseer, Saudi Arabia
Follow the datasheet exactly (Provided it has brighteners from a supplier). When all else fails give it a dose of Ammonium Hydroxide. Test in a Hull Cell first!
Jon Quirt- Minneapolis, Minnesota
