Zinc Ammonium Chloride Solution Specific Heat Capacity
I want to know the range of the values the flux solution (Zinc Ammonium Chloride ZnCl2.3NHacl) Specific Heat Capacity in order to be able to calculate the Heat Exchanger Capacity needed to heat up my fluxing tank in a hot dip galvanizing plant.
Thanks for any help,
Izzdeen A. Abu Hijleh
Al Jazira Metal Industries Company - UAE
Specific Heat capacity of zinc ammonium chloride in solution is 6KJ/Kg.K
Hlalele Lekhooa
- Fouriesburg, Freestate, South Africa
July 6, 2009
