Basic definition of galvanneal steel
What is "galvanneal steel" Is it different from galvanized steel?
Khawaja Masood
- Karachi, Sind, Pakistan
Yes, Galvanneal is different from conventional galvanized coatings. The galvanneal process creates a zinc-iron layer, instead of the usual zinc layer created during hot-dip or electrogalvanizing. You can obtain more information from producers of this product:
http://www.dofasco.ca/PRODUCTS_AND_MARKETS/products/galvanneal.html
http://www.weirton.com/products/galv/galvanneal.html
http://www.usx.com/corp/sheet/coated/coatneal.htm
Toby Padfield
- Troy, Michigan
Hi, Khawaja. Thanks, Toby.
Perhaps the principle significance of the difference between galvanneal and conventional galvanized steel is that galvanneal is designed to be painted and is relatively easily painted whereas it can be troublesome to get reliable adhesion of paint onto galvanizing.
June 27, 2009
Does roll-forming this product cause dust?
Nick Giampaolo
- Grayslake, Illinois, USA
August 5, 2009
