Can a part be black hard anodised after chemical film finish ?
I have a part of material Aluminium alloy 7075-T651. It has called for chemical film finishing followed by hard black anodise per MIL-A-8625 / MIL-PRF-8625 [⇦ this spec on DLA], Type III, Class 2. Is this doable. Isn't chemical film coated surface enhances adhesion of subsequent coatings
Nelson Toh- SINGAPORE
You cannot apply a controlled oxide coating over a chromate conversion coating, Period. However, maybe your customer wants chromate on part of the surface and hard coat on the other. Such a combination is a frequent call out. This is done by various different kinds of masking.
First of two simultaneous responses -- 2003
You may be able to do both process on a same part. Try the following process : Pretreatment - Masked the surface for Chemfilm - HardCoat - Seal at boil using nickel acetate sealant - Remove Maskant -Chemfilm.
Good Luck,
S. Y. Yuen- Hong Kong, China
Somewhere you are missing the Masking indication. This is a common call-out in the industry.
Bill Grayson- Santa Cruz, California
finishing.com is possible thanks to our supporting advertisers, including:
