Acid + Carbonate = what reaction?
1       2
Q. Why when you react calcium carbonate with acetic (ethanoic) acid how will it (in the terms of lime scale) actually get rid of it. What does it do to the calcium carbonate that dissolves it?
Harri [last name deleted for privacy by Editor]
- Hamphire, UK
November 17, 2012
A. Hi Harri. The reaction is the same as shown under September 25, 2012 except using acetic acid this on eBay or Amazon [affil links] rather than hydrochloric acid. The acetic acid converts the calcium carbonate to calcium acetate, water, and oxygen.
It is difficult to explain "why" because the depth of explanation should depend on what grade you are in (what depth of knowledge you already have that we can build on), and because as Richard Feynmann told us, no matter how deeply we study, we actually only learn "how" in greater and greater depth, we never learn "why" :-)
But in reasonably simple terms, the reason it does this is that the reaction products have a lower energy state than the original ingredients. So putting the ingredients together releases a small amount of heat, and as the heat dissipates, the reaction flows one way instead of back and forth. And once the carbon dioxide fizzes off, it's no longer there, further preventing the reaction from reversing. If you have a coin standing on edge on a table, and you shake the table, the coin will fall over on its face and stay there. Further shaking is very unlikely to get it back up on its edge because it's at a lower energy level when it's lying on its face. In the same way, heat is released by this reaction, so it doesn't flow the opposite way.
November 19, 2012
Q. Is a reaction of any acid and any metal carbonate going to be endothermic like ethanoic acid and sodium carbonate?
Miles [last name deleted for privacy by Editor]
- London
November 29, 2012
A. Hi, Miles.
I would have doubted it. Most simple reactions are exothermic. I believed that reactions involving acids plus metal carbonates are exothermic. But I see a PhD on the internet describing an experiment proving it to be endothermic. I think the idea of your lab is to put a thermometer into the reaction cup before during and after, and see whether the thermometer reads higher (exothermic) or lower (endothermic) as the components mix. Good luck!
December 2, 2012
A. Hello Miles,
There are many variables making this kind of reactions endo or exothermic. As they have as result a gas (and the reactives are liquid or solid), the final entropy of the system is many times higher as the initial entropy. This has no relation with enthalpy variation (negative means endothermic, positive means exothermic).
Enthalpy is just an experimental value, that can be measured theoretically with some physicochemical models, but its root is in experimental values. There are tables with enthalpy values that can help people to estimate enthalpy variation, thus being able to tell if a reaction is exo or endothermic.
So, there are infinite possibilities... Good luck!
Daniel Montañés
- Cañuelas, Buenos Aires, Argentina
December 11, 2012
January 9, 2013
I am doing 8th grade science fair and I have reacted every carbonate I can find with acids (HCl, nitric, sulfuric, phosphoric).
My first question is probably easy: does the CO2 and H2O always form because carbonic acid was formed first?
I have been researching for MONTHS and cannot find the answer to this question: what are the intermediate steps to each reaction.
Do you know if every Group 1 & 2 metal carbonate + acid have the same reaction steps? Are they all like this?
MCO3 + HA = MA + MHCO3 + HA =
= MA + carbonic acid =
= MA + CO2 + H2O
Thanks! Emma
Emma [last name deleted for privacy by Editor]
- Miami, Florida, USA
A. Dear Emma,
The carbonic acid is very unstable as itself, as it cannot be measured with any instrument. There are theories that mention the carbonic acid as an intermediary to carbon dioxide and water, but the state "carbonic acid" readily decomposes because of the low energy and high entropy of the product states.
It is, the most energetic and organized state, tends to decompose into lower energy and more disorganized states. As you are forming a gas, the product state is very disorganized, and thus the entropy is high.
Carbonic acid is a theoretical substance that we cannot handle in experiments, so its energy must be very high, and so it is very unstable. Some facts in chemistry are empirical, and so comes a theory (later) that sustains the fact ;)
Hope this clear some of your doubts! Regards,
Daniel Montañés
January 15, 2013
thumbs up signThank you! That really helps and that's probably why I couldn't find a whole lot of information :)
January 18, 2013
Q. Please tell me sir. What is the reaction between palmitic acid and sodium carbonate?
Sudhakar M. [last name deleted for privacy by Editor]
- Hyderabad
January 30, 2013
A. Hi Sudhakar. I'm happy to help, but believe it's injurious to education to offer an answer unless the student understands the question. To assure me, please write the left hand side of the equation, and I'll supply the right. Please remember that in writing chemistry formulas, proper spelling and capitalization are essential; anything less is an outright error that may get you flunked. Good luck.
February 2, 2013
Q1. Sir, Can you please explain to me how non-metallic oxides are acidic in nature?
Q2. And also whether slaked lime and lime water are different from each other?
Navrishka Fernandes
- Ponda,Goa, India
June 16, 2013
A1. Hi. Navrishka. Can you give us an example of a non-metallic oxide and tell us what "acidic in nature" means to you, so that we are confident that you truly understand the question you are asking?
A2. Slaked lime is Ca(OH)2. It may be a solid or it may have water added and be a solution. Limewater is a "saturated solution" of slaked lime. I.e., if you add slaked lime to water, and keep going until no more can dissolve and it starts accumulating as a sludge at the bottom, and then you put it through a filter so none of the sludge gets through, so you have the maximum possible amount of slaked lime dissolved in water, that is lime water.
June 23, 2013
Q. When vinegar in bulk on eBay or Amazon [affil links] , salt, calcium chloride, sodium benzonate and water are mixed (which is the basic mixture of dill pickles), does a chemical reaction turn it into another chemical?
Doris Culv
Brain Blossom creations - Thomaston, Georgia usa
March 17, 2015
A. Here's an answer from a chemist; probably TMI.
You have 3 cations, H+, Na+ and Ca++.
And 4 anions, OH-, benzoate (not benzonate; I'd be pretty sure of that), chloride, and acetate (from vinegar, which is acetic acid).
So 12 salts are produced; they are partially or completely ionized, are in solution with the cations and anions themselves, all in equilibrium with one another.
tom_rochester
Tom Rochester
CTO - Jackson, Michigan, USA
March 19, 2015
Q. Why is it necessary to expel carbon dioxide from the reaction between sodium carbonate and hydrochloric acid?
folakemi ayodele
student - Yaba, Lagos, Nigeria
April 11, 2015
A. Hi folakemi. It is necessary to allow the carbon dioxide to be expelled because it occupies more volume and could explode a sealed test tube.
Are you sure you understand the question that you have posted though? People can help answer your posted questions, but if you post your teacher's question like a parrot, without understanding it, it's a problem. Tell your teacher if you don't understand the question.
April 2015
Q. Is there a chemical reaction if you add calcium carbonate and HCI? Why do you say so? And is there a change in the total mass before and after the reaction?
Alyanna R [last name deleted for privacy by Editor]
- United States
June 14, 2015
June 2015
Law of Conservation of Mass:
In a chemical reaction, the mass of the products equals the mass of the reactants.
thumbs up signHi Alyanna. Sorry, I've never heard of HCI, and doubt that it exists. It could just be a typo, but are you sure that you at least clearly understood your homework assignment?
A. I have also never heard of HCI and doubt if it is a possible material. Your HCI is probably HCl. Ask your teacher.
Most text books have this or a similar reaction in the text.
If not try the internet.
With HCl, it is a very common reaction. Note the conservation of mass in blue print in Ted's answer.
A. Alyanna,
Back in the day before widespread internet, students needing help would have to ask one of their classmates or even the teacher. Somehow I suspect either of these would still be faster than an internet forum.
Of course one can't be blamed too much for confusion between, let's say, a lowercase l, a capital I, and the number 1. However, chemistry students are expected to be familiar enough with the common elements to be able to pick out when something is likely to be chlorine. HCl is of course hydrochloric acid.
At this point it would be apt to point out that hydrochloric acid is a strong acid, and carbonic acid is a weak acid. If you are familiar with conjugate bases (or able to look that up right now), that should tell you something about what's going to happen first. Carbonic acid also has a very special property that I'm sure your textbook talks about, and I know Wikipedia talks about, that plays an important role in what happens after that.
ray kremer
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
June 17, 2015
sidebar notes
! Though I know it is partially true, seems like this thread has some people who believe that modern day people are stuck to technology and don't do real experiments. I know this is partially true, and I know you are not meaning for it to apply to every school. I personally know for a fact that all the schools in my area do experiments in science class. I mean real experiments. And I work with HCl at school almost every class. We sometimes, for fun, get to do take home experiments so we can debate about it at school. Addressing the matter of technology, I think you are missing that technology helps us as well. Scientific research and findings can be easily accessed online, and if need of contact of either teachers or students there are now so many ways we can do it. This is not meant to jab at anyone, I am simply informing :)
Megan Ng
- Hong Kong SAR, China
September 21, 2015
thumbs up sign  Thanks Megan! This internet forum has been my life's work for 25 years, so I'm certainly not opposed to the internet! -- but when improperly applied it can be an impediment to learning rather than an aid.
A point which you made much so better than I did, is that while chemophobia and aversion to risk is currently resulting in American children failing to get a solid science education, you and most Asian students keep doing real science! So when you are adults, Western students will probably be flipping 'burgers for you and your classmates :-)
Q. I don't know whether a reaction between calcium carbonate and nitric acid is a neutralisation reaction or not.
PLEASE HELP ME MY LIFE IS HANGING ON THE EDGE OF A LINE. LITERALLY.
PLEASE HELP ME OR MY LIFE WILL ALWAYS BE A LIE!!
Larry P [last name deleted for privacy by Editor]
- London, England
January 8, 2016
thumbs up signTry writing the left hand side of the equation and we can go from there.
… or put pH paper in the nitric acid before & after you add the calcium carbonate and tell us the readings.
… or content yourself with flipping Megan's burgers :-)
January 2016
January 8, 2016
A. Larry,
Quick hint: Look up carbonic acid on wikipedia, that will give you two key pieces of information about what carbonate will do in the presence of a strong acid.
ray kremer
Ray Kremer
McHenry, Illinois
A. Yes, it is a neutralization reaction. It is also a replacement reaction. It is also an exothermic reaction. The amount of CO2 will somewhat depend on rate of reactions/strength of the reactants. It is possible for some to remain a ionic carbonate. Resulting pH will be a result of how complete the reaction is and how much of an excess of either component is.
Q. I had an experiment in school in which we had to react calcium carbonate with HCl to to show the amount of carbon dioxide produced from temporary hardness of water, but I would like to know the scientific explanation of the effect of percentage hardness on the amount of CO2 produced. Also I would like to know if the reaction turns the solution warm or cold because my lab partner who was holding the conical flask said it turned cold, but while reading through this thread it says it turns warm.
ghada shalaby
- fujairah, UAE
February 19, 2016
Q. I was wondering with this discussion if anyone could tell me if my reaction for calcium carbonate and sodium acetate is correct? I am not sure if my acid is strong enough to dissolve my base:
Ca(OH)2 + 2 CH3COONa = Ca(CH3COO)2 + 2 NaOH + H2O + Na+
Additionally I have a second reaction with acetic acid added as a buffer and wonder again if this is correct:
(CaCO3), + CH3COONa (CH3COOH) = Ca(C2H3O2)2 + NaOH + CO2
any feedback or suggestions would be greatly appreciated
Kiri Rodgers
- Glasgow, Scotland, UK
March 23, 2016
March 24, 2016
A. Kiri,
Calcium carbonate CaCO3
and
sodium acetate NaCH3COO
are both salts. Mixing them won't cause any reaction.
You wrote out an equation using calcium hydroxide Ca(OH)2, but again, everything will just dissociate into water, there is no real reaction there. Note that the equation you wrote is not balanced. You should have just stopped at
but all that does is swap the cations around, which is meaningless when all the compounds listed are soluble.
So then your second reaction equation, calcium carbonate + sodium acetate + acetic acid
CaCO3 + NaCH3COO + CH3COOH
Now I'll give you two hints. Ignore the cations and the acetate ion, and read above my January 8 2016 reply to Larry. This would be more involved if given specific amounts of each and asked to find the final equilibrium concentrations, but just a matter of "what reaction will occur" is simple enough.
ray kremer
Ray Kremer
McHenry, Illinois
Q. Hello, I was curious as to what type of reaction calcium carbonate + hydrochloric acid is. I believe it is a neutralisation reaction however other sites have said it is either a decomposition reaction or double displacement
The reaction -
CaCO3 + HCl -> CaCl2 + H2O + CO2
John Webster
- Brisbane, Queensland, Australia
April 7, 2016
A. Hi John. I count one Hydrogen and one Cl atom on the left side of your equation, and two of each on the right. Your error is a very small one, and perhaps only typographical, but before you ask a question about a reaction, you must write it in excruciatingly correct form because if it's not balanced it's nonsense and it doesn't make any sense to talk about it at all.
Yes, it's a neutralization reaction! But just because you believe that a particular dog is large doesn't mean he can't also be a black dog or a friendly dog. You'll need to study what a decomposition reaction is, and what a double displacement reaction is, and decide whether the reaction between CaCO3 and HCl qualifies or not because we can't assume it's a multiple choice question :-) ... but I don't believe it to be a decomposition reaction or a double displacement reaction. Good luck.
April 2016
Q. Hey, I want to do an experiment of making limescale.
I want to know if the reaction will happen.
I want to boil water at glass and at glass wrapped in aluminum foil.
I want to boil it for 30 min.
Will I see the formation of limescale? How much time it take to see the formation of limescale?
or izqovich
student - Tel Aviv, Israel, Israel
July 12, 2016
A. Hi Or. Yes, that sounds like a good experiment, and good questions for the experiment to answer.
But you can't get more carbonate in the limescale than was in the water, so you obviously won't get much limescale without significant carbonate in the starting water. Good luck.
July 2016
Q. Why do we use vinegar to descale a kettle?
Magdeline magetse
- Gaborone, Botswana
August 8, 2016
A. Hi Magdeline. vinegar is acetic acid, a mild acid. The scale is calcium carbonate.
As you see on this page, mild acids like vinegar will react with the calcium carbonate and dissolve it.
The Ladies No. 1 Detective Agency, set in Gaborone, is an all-time favorite book series, so I'm always delighted to receive a letter from Gaborone :-)
August 2016
I'm mona and I'm in seventh grade.
I need to complete my lab record so somebody please help me.
I need to know the whole experiment of carbonate salt with acid. I need the aim, materials, procedure, observation and the result.
If anybody helps me I will be very thankful to them.
Mona R [last name deleted for privacy by Editor]
- London, England,UK
September 25, 2016
A. Hi Mona. Hopefully, if you just read this one page you will be well on your way towards understanding.
The teacher gives you the aim. Charles Darwin himself said that to try to do science without a hypothesis is to waste your life in a gravel pit sorting the stones by size and color.
In seventh grade I doubt that you are supposed to determine the materials and procedure yourself; that would be too dangerous at your age. Again your teacher gives you this.
Your observations are what you see and note when you follow the procedure -- any and all detectable changes. The result is your conclusion about what probably happened. A conclusion does not have to be airtight like a proof in mathematics; it may include suggestions for what should be done next time to strengthen the conclusion.
September 2016
wikipedia
Calcium carbonate
Calcium chloride
Carbonic acid
Q. I'm currently working on a chemistry lab for determining reaction types and balancing them. I'd like to be able to know why it is that
CaCO3(aq)+2HCl(aq)→CaCl2(aq)+H2CO3(aq)
is incorrect, along with how to determine what state each reagent should take and why. Thank you for your time.
Ishad Zaman
- New York City, New York, USA
December 16, 2016
A. Hi Ishad. I'm not sure that your equation is actually wrong; it looks okay to me. But there is a proviso, because the subsequent equilibrium reaction:
H2CO3 <-> H20 + CO2
shifts very strongly to the right. So
CaCO3+2HCl→CaCl2+H2O+CO2
is probably closer to the actual situation.
CaCO3 is quite insoluble, so I'm not sure the '(aq)' really belongs next to it, '(s)' might be better; but '(aq)' seems an appropriate description for the state of the other compounds. Good luck.
Why worry about "burning" copper sulphate?
Q. Hello. At my institution, the experiment of creating copper sulphate this on eBay or Amazon [affil links] crystals was conducted by adding copper carbonate this on eBay or Amazon [affil links] to sulfuric acid. I noticed that while the solution was over the Bunsen burner's heat, we were instructed to prevent the mixture from burning, and I was wondering why. I know the mixture was to be saturated but why can't it be boiled? Can you please clear this up for me?
Regards from the wonderful Caribbean,
Palmalaya.
Palmalaya Maharaj
- Trinidad and Tobago, West Indies
February 14, 2017
A. Hi cousin Palmalaya,
copper sulphate crystals are CuSO4.5H2O. It seems to me that burning the mixture will drive off those five parts of water so you can't get the crystals you seek.
February 2017
Q. Please I would like to know, why during hydrochloric acid and sodium carbonate react we add extra hydrochloric acid?
napandulwe sheehama
- windhoek, namibia
September 14, 2017
Q. Why is very little carbon(iv)oxide evolved when lead carbonate reacts with sulfuric acid?
JANET MWAMIDI
- KENYA
May 19, 2018
A. Hi Janet. I'm not sure that you fully understand the question, and I don't really like to offer answers if the question isn't understood because it wouldn't help your education … but what do you think would happen regarding the amount of evolution of carbon dioxide if, as soon as the sulfuric acid started dissolving the lead carbonate, you pulled out your remaining lead carbonate and coated it with acid-resistant glass and then put it back in the acid?
May 2018
Q. Does acetic acid and calcium carbonate produce heat?
Isabel Ann
- Orange, NSW, Australia
June 3, 2018
A. Hi Isabel. I think the idea is to let your acetic acid and your calcium carbonate stabilize to room temperature, put the bulb of a thermometer into the dish of calcium carbonate crystals, then pour the acetic acid onto them while observing what happens to the temperature as the reaction takes place.
Although it's not true of 100% of cases, most chemical reactions of that general sort do produce heat.
When I was a kid I had an older sister who I naturally wanted to play with; and being an older sister she sometimes didn't want to. So one day when I nagged her she invited me to play "52 pickup", which it turned out consisted of her taking two seconds to throw a deck of cards around the room and me having to spend 5 or 10 minutes picking them all up.
The lesson being that it takes much less energy (heat) to move things from a state of order into disorder than it takes to move them from disorder back to order. It's easy to mix acetic acid and calcium carbonate; it's quite hard to make the reaction run backwards to get the starting materials back; that's an indication that when they mixed they probably released energy (heat) and that it will require energy to restore them.
June 2018
