Why does Ni prevent Cu migration to Au?
Dear Sir,
I am new in electroplating field and I would like to know why Ni prevents the migration of Cu to Au?
Thanks a lot Regards,
KT
- Hong Kong
Dear sir,
For better understanding please compare ionic radii of Au, Cu, Ni with each other you will find out the mechanism.
Hadi Khosravi
Tavaanazmayan - Tehran, Iran
Cu migrates into Au by forming a solid-solid solution. Ni doesn't form a solid solution with Cu or Au, so it acts as a barrier.
James Totter
James Totter, CEF
- Tallahassee, Florida
The nickel is a "barrier layer" that stops the diffusion of copper into the gold. It is all to do with the "solubility" of one metal in another.
