Inquiry for surface roughness
I want to know how to convert value of millimicron to Grit. I have a value of surface roughness in millimicron & I want to convert it in to Grit. So please tell me how to convert it.
Prashant G. Prabhu- Mumbai, Maharashtra, India
There are charts available in either millimeters or inches that correspond to grit sizes, or at least a size range. Meaning, grit is that size which falls through a certain screen hole. That separation or classification system gives you a range of grit size and can be shown as a 4 digit high and low number when media gets to a larger size. The surface finish of the materials being worked do not directly relate to grit sizes.
AF Kenton
Dear Sir,
You have mentioned that there are tables - Grit to Microinches/Micrometres. Where can I get them?
Thanks in advance.
Ranganathan ElaneeraEngineering Consultancy - Singapore
We convert the reading (Ra 0.007 ìm ) into micro mm to micro inches.
Chetan M Shah- Hosur,Tamil nadu, India
