Electrophoretic paint and hydrogen embrittlement
I have a torsion spring application where cyclic fatigue is critical. The salt spray requirement is 96 hours. Our vendor is recommending a electrophoretic paint finish but I am concerned about hydrogen embrittlement. Hydrogen embrittlement quite often is the cause of spring failure. Is hydrogen embrittlement a concern in electrophoretic painting? And how important is type of cleaning in minimizing the risk of hydrogen embrittlement. What is the typical electrophoretic paint process? Does it include a bake operation at the end?
Tim Zwit
- Spring Lake, Michigan
Hydrogen embrittlement is not an issue in electrophoretic coating. Two reasons: One you deposit an organic layer therefore hydrogen does not get entrapped in the metallic lattice. Two the coating is cured at 170 °C. The process involves pre treatment to obtain a phosphate coating followed by E-coat and baking.
Hope that helps.
Gurvin Singh
Mohali, Punjab, India
