Needing to darken pewter
I am in need of information on how to age pewter. This pewter has been formed as legs like a spider on a chandelier with lights at the end. The owners are wanting the pewter to be turned dark or black and I do not know how to do this or what to use. Please Help!
Nancy Sandifeer
- Dike, Texas
Nancy,
Sorry, but I don't have the foggiest idea as how one should age darken your pewter. Nor did you say if your pewter candelabra was modern or old.
Modern pewter is, as far as I know, pretty 'bright' and silvery. Old pewter is dark ... I have a collection of pewter mugs, mostly modern, starting in 1922 ... but one is 1790-1810 and pretty dark.
As the modern pewter contains much less (poisonous) lead and more tin (I believe), maybe it may not lend itself to darkening. Why don't you try a drop or two of acid or bleach to see what will happen.
Am sorry that I can't be of any further help.
freeman newton portrait
Freeman Newton [dec.]
Jax Pewter Darkener
Try Jax Pewter Blackener .
You can purchase this on line.
Hans Jaegerstatter
- Cambridge, Massachusetts
April 27, 2009
