Pontoon Boat - Aluminum Panel Repainting
I have some aluminum pontoon boat panels (above the water line/deck mounted) that need repainting. I am not intending to remove the original paint (light brown). I will paint over it. What prep and paint type is advisable? I may have to mechanically remove some adhesively applied striping which may expose bare metal. What is the best prep for the bare aluminum surface that may result. Will the use of this prep and its contact with the light tan paint to be painted over adversely affect the adherence of the new coat to the original paint?
Bob B [surname deleted for privacy by Editor]
- Springfield, Massachusetts
Pontoon and Hull Cleaner
Hi, Bob. Sorry no one replied to your inquiry previously. letters 21588 and 31788 have pretty good discussions on the topic of aluminum pontoons which has at least some applicability.
There is no need to remove adherent paint, so you are on the right track. You may be just fine with a prime coat designed for aluminum. But if you are a purist, the proper pretreatment of bare aluminum is actually a chromate conversion coating consisting of two steps: cleaning with Alumiprep 33 this on eBay or Amazon [affil links] and chromate conversion coating with Alodine 1201 this on eBay or Amazon [affil links] before painting. These are hazardous materials so you may have to pay a shipping surcharge; use them carefully.
